zzouriparts
- Jan 29, 2011
- 0
- Ford
My son has a 1989 Bronco II (in very nice condition I might add) and the cruise is inop. Don't know alot about cruise, however we have checked the obvious, conections, fuses, hoses and so on. All components are present and accounted for and all connected as they should be (for what I know). The only questionable connection is the plug to the brake reservoir. When I pulled on that plug it more or less came apart, the wires came out of the plastic connector. So, we don't know if it had been like that before and some one did not reinstall the wires correctly, nor do I know if I reinstalled the wires correctly. The three wires are one black, one purple/white and one purple/yellow. Does anyone have a picture they could post of that connection showing the correct wire positioning. Once we isolate this (and if it doesn't fix the problem), then we can move on to something else. Thank you for any help, it is appreciated!
