Bronco II Drive shaft.
bug11
I thinking on switching my 1986 bronco II to From Auto to 5 speed. My question is The drive shaft on the auto the same for a stick? and will the brake and clutch peddles from a Ranger be the same as a Bronco?
Thanks Mark
trail B2
8
North Eastern Ca.
I put in a M50D and it's the same length so no drive line problems but remember the drive line goes to the transfer case.There is one tranny that fits thats a different length its in the archives.
The peddles out of a Ranger do fit the early 90s peddles fit too B2 ,ranger and explorer.From the back of the doors forward it really is a ranger.
Junk Collector
Truck of Month
4,887
Rapid City SD
You can swap in a M5OD or FM146 and not have to change driveline lengths. Can't do the same with a TK-4, TK-5 or FM145.
disciplerocks
July 2011 OTOTM Winner
53
Evansville, IN
What they said. Its not the tranny, but the transfer case that matters.
Junk Collector
Truck of Month
4,887
Rapid City SD
Haha other way around man. All three versions of the 1350 and the 1354 t-cases are basically the same length.
disciplerocks
53
Evansville, IN
Not from my measurements at the u-pull when I had to replace mine. But I was talking about the style joint.
Junk Collector
Truck of Month
4,887
Rapid City SD
Assuming they have the same flange on the rear output, they are the same length. The earlier 1350's have a different style that could throw the measurement off slightly, but not much.
Anyway the earlier transmissions like I mentioned above will require driveline length mods because they are NOT the same as the A4LD he's pulling out.
