Bronco II hot start issues
robotzombies
13
Seattle, WA
2.9
3"
33"
1989 Bronco II XLT 2.9l manual transmission
I've been having a problem lately where the truck won't start when hot. Both when the engine is hot and when the temperature outside is hot. It will pretty much always start first time in the morning; any other time, it will start, but after a couple of tries, and those tries involve slamming the clutch pedal to the floor.
It doesn't turn over at all. I get silence when I try to start it (the threads on the forum talking about the hot start issue tend to talk about the truck being able to turn over). The truck seems to run fine when it does start, no sputtering/fuel issues, everything works, battery gauge sits at about 13 volts. I've already replaced the coolant temp sensor.
Any ideas? My guess would be something with the clutch pedal, but I don't know where to start with that.
alwaysFlOoReD
5,156
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Next time it happens, put the e-brake on, put shifter into neutral, key on and use a screwdriver to jump between the small and big terminal on the fender solenoid. That will take the clutch safety switch out of the equation.
4.0B2
151
Walls, MS
4.0 v6
Is there a way to bypass the clutch safety for the member?
Also could be starter. If the starter is weak the heat can make it do weird things.
robotzombies
13
Seattle, WA
2.9
3"
33"
I was able to bypass the solenoid, and I ended up replacing it. Still have the same issue, even with the replacement.
I'll see if I can get the starter tested. I think I will also check out the ignition to see if anything looks out of place or wrong.
alwaysFlOoReD
5,156
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
The solenoid wasn't what I was suggesting testing/replacing, it was the clutch switch.
The clutch switch is up by the pivot of the clutch pedal, it will have two wires going to it. If the clutch is not depressed the switch will not allow the engine to crank.
Jumping the solenoid with a screwdriver bypasses the clutch switch.
robotzombies
13
Seattle, WA
2.9
3"
33"
I am currently and temporarily bypassing one of the functions of the switch by connecting the 2 pink wires going into the switch connector. I think these wires control the ability of the truck to start when the clutch is depressed. So far, the bypass seems to work.
Jumping the solenoid with a screwdriver bypasses the clutch switch. .
I think you're right in thinking it's the switch. Like I mentioned, I've bypassed it for now. I bought a new switch, so when I get some time, I'll install it to see if it fixes the problem.
Thanks for the help, guys.
