trader007
- May 22, 2010
- 2
- Ford
1999 Ford Ranger XLT
4x4
Extended Cab
Problem?
Truck hesitates under load. Miss fires under load/low rpm. sometimes, especially when cold i have to hold the pedal to the floor while it bucks and misses just to get it up to 50mph. after the engine fully warms up it usually stops missing and i can literally power brake the back tires until they smoke. some days though, it just never comes around and it runs like crap.
Solutions?
"Everything". I kid you not, I am a car guy, have a good scan tool, pressure guages, voltmeters... and have been chasing this slowly growing problem for 2 years now. About 4 months ago I just started throwing parts at it.
New parts- (not all related to problem, I know, but listing anyway)
coil pack/plugs/wires
fuel filter
fuel pump
o2 sensros (all three, although they are 80k old now)
transmission (fully rebuilt)
Lower intake/upper intake gaskets
air temp sensor
mass air flow sensor
idle control motor
pcv valve
crank sensor
camshaft position sensor
water temp sensor
injector cleaner (which never made a damn bit of difference)
64lbs of fuel pressure (perfect)
no vacuum leaks
only codes that come up are "system too lean" which is on about every millennium era ford.
took apart and cleaned every connector i could find, with deoxit cleaner and then coated with dielectric grease for water protection.
Ok, so without getting into a whole lot of background, let me lay out some history that I am 99% certain on.
The problem is in the ECU.
I have taken a couple pictures. You can see where I added new caps. They are doing some sort of power filtering, and when I replaced them it made a HUGE difference. in fact, for almost 2 weeks the truck ran like a wet dream. thought i fixed it, but it slowly went back to missing and bucking under load.
Now, the caps are still fine. I even replaced them again and no change.
Does anyone have any sort of knowledge as to what normally goes wrong with these, besides the caps? Its a bitch to work on, the whole thing is covered in dried silicone. I do know this ecm directly controls the voltage that drives the fuel injectors and the ignition coil.. and from the way it runs it does seem like a spark issue (i will get immediate full power and then back to missing all the time... its very instant and very random)
My soldering is a lot better than it looks too. I am tired and a little frustrated, if you can imagine.
And I will tell you, my biggest problem here is identifying the components. I can test most stuff, but without knowing what it is to begin with I don't know what to test. If I had a datasheet for this computer it would be done by now
4x4
Extended Cab
Problem?
Solutions?
fuel filter
fuel pump
air temp sensor
idle control motor
pcv valve
crank sensor
water temp sensor
no vacuum leaks
