buick clicker
martin
26
St Bruno, Quebec
1991
My neighbor has a late model buick and I believe the battery needs changing in his clicker. Can you just change the battery or do you need to go through some kind of re-programming procedure?
B2 Addict
9
Lavergne, TN
Solid Axle Swap 4x4
37x12.50-17
I recently changed the battery in the clicker for my '96 Dodge, that's all I did & it works fine.
martin
26
St Bruno, Quebec
1991
As there were so many responses to my question I thought I should post what happened after I changed the battery in the clicker. It worked perfectly.
The clickers have an ID code burned into them. The program procedure pairs the clicker to the car by telling it "this code is good". It doesn't pair the car to the clicker.
