Building me a N/A junkyard motor.
cody93
42
Duluth GA
FORD
well, i managed to get a job finally so i'll have some extra cash, one of the things on the list is a spare motor for the 87, thats better than stock...
end goal is a stout N/A motor that makes about 120-130hp and 9.5:1 compression.
Onto the partlist!
89-9x block, the one with the distibutor hole provision.
98-01 crank rods and pistions
91 mustang head
93+ tube manifold
unsure about intake setup yet...
mods are port n polish, heatwrap the exhaust manifold, shave the head a little mabey even shell out the cash for forged rods and pistons..
are my power goals realistic? will the parts play nice with each other, did i miss any other tricks?
DJ2.3
2.3
Before you shell out for a forged bottom end, I would get a mild cam, and if you get the cam you can really mill the head-like .060+. With the mods you have listed you should be at 130hp if you mill/ port the head enough. Put a good cam in and mill .080 off and you should be at 150. I think i would put ARP rod bolts in if you want to spin it over 6500 much.
cody93
42
Duluth GA
FORD
a good cam sounds like a good idea, will definitly(sp) be using good quality fasteners for sure. i wonder how much off the head i can mill before it becomes an interference engine or compression gets above 9.5:1, which is probly the highest 87 octance can handle, probly should use 9.4: like on the mid 90's engines..
DJ2.3
2.3
keep in mind that if you have a longer duration cam, the valves will be open longer. That will lower your dynamic compression ratio. So with a bigger cam you can get away with running more compression.
chilsam
chillicothe il
91 branger
300 six
mustang svo site
Onto the partlist!
91 mustang head
93+ tube manifold
mustang svo or turbo t-bird sites
You can pick up some good deals on forged parts.:icon_welder:
logman7777
South Western NJ
2.3
From what I have gathered from the Merkur sites and such shaving the head .060 , gasket match/ rough polish and your selection of the shorty OEM "header" should get you close to 150 w/o playing with a cam. As long as you dont want to rev the snot out of it and keep within its stock redline you dont need forged pistons or ARE studs either. :headbang:
