Burning Coolant
RangerBoy94
24
Northern California
360CDI
Alright I've been searching for days and cannot find any information that pertains to me. About 3000-4000 miles ago I did a total overhaul to my 4.0. New gaskets, seals, water-pump, thermostat, rebuilt injectors, honed the cylinders, new rings, valve guide seals, cleaned the block and heads very good, and I relapped the valves. So my engine should have run very good I saw 0 problems when cleaning everything. Well she likes to drink coolant very much. I dont have any milky oil and I dont burn oil so I'm kinda stumped. My engine temp is always perfect its never been hot I could run it without any coolant and it wouldnt get too hot. My oil pressure is also high. At this point I have no clue what the problem is. Help!!!!!!!!:bawling:
srteach
9
Ranger, F350
4.0L, 7.3 Diesel
Do a compression check in each cylinder. You will probably find a blown head gasket.
Rose2300
7
ID
Toyota
3.4
maybe you have a leak that you didn't notice before
98 ranger xlt
California
Did you check the heads for cracks when you rebuilt it? these motors like to crack heads.
marktonium
Have you checked the freeze plugs?
I think there are three on each side and TWO in the rear of the engine. 8 total. Make sure your engine is cool (obviously) and slide your hand between the engine and firewall to see if there is any wetness.
