C-Clip Eliminators VS Full Float
95XL
Fulton, NY
7.3L Diesel
I've been trying to do some research but have come up short on what I want to know about these two things. I've seen C-clip eliminator kits for the 8.8's, and was wondering what they do, as compared to a full float rear axle. As I understand it, in a full floating rear axle the only thing the axle shafts are used for is turning the tires, as compared to a c-clip rear end where the axle shafts actually support some of the weight of the vehicle, as well as turn the tires. Am I correct about the two things I mentioned above?
I've seen the warn full float kit for the 8.8's, and was wondering what the difference was between that kit and the c-clip eliminator kits? Are they pretty much the same thing?
I've been working on my dual wheel conversion on my ranger, and have everything pretty much buttoned up, but I'm worrying about the rear axle. I've got an 8.8 out of an explorer I'm going to swap in, but was wondering if I should buy a c-clip eliminator kit. On the other hand, I was contemplating buying a full float Sterling out of an F-250, and just adding 2" spacers (I'm using dually rims for the conversion with the 8 on 6.5" bolt pattern). What is your opinion?
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
A c-clip eliminator kit simply changes the method of shaft retention in the housing, it does not change it from semi-float to full-float.
To change the 8.8 to full-float, you would need to add spindles and separate wheel hubs onto it (like how the F-250 axle is set up).
Sprag-O
Canton, NY
Mazda
2.3L
Should change it to semi float right? the weight on the axleshaft is then handled by a bearing cup at the end of the axle when setup with the eliminators...
eliminating the C-clip doesnt make it a semifloater.... as the Corp14 9.5 SF axles C-clip... But the bearings on the end should...
Semi-float fastens the wheel directly to the flange on the outboard end of the axleshaft, and a single bearing supports the outer end of the shaft. (Pulled from quadratec)
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Huh??
Semi-float only means the shaft supports the weight of the vehicle on a single bearing. This doesn't change with eliminating the c-clips.
Mutant Pony
9
Hersey, Mi
2300
Yup. Somebody got their wires crossed. The stock 8.8 is a semi floater. A full floater has two bearing sets on a spindle which handle the load. All duallies SHOULD be full floater.
95XL
Fulton, NY
7.3L Diesel
Ok, thanks guys. The more and more I research this subject, the more and more I'm leaning towards swapping in the Sterling.
The only thing I can see posing a problem is those gigantic brake drums. Would my stock master cylinder be able to make enough pressure to move those wheel cylinders?
Luckily, they only came with three different gear options, so chances are pretty good of finding one with 4.10's already installed, saving another headache.
