C105f connector pin out ?
prymetime1
Hey all, was wondering if anyone had thr circuit functions for the pins on the c105f connector on the firewall.
I was able to find the following pics online.
Any help here is appreciated.
Thanks.
truckerdawg
5
GA via NC Mtns.
4"
31X10.50
Sorry. But these plugs must be one of the most highly guarded secrets by Ford.
prymetime1
You ain't kidding man...I cut out what I didn't need so I guess at this point I could tell u what pins are what for the basic funtions.
3,614
The problem I ran into with my own investigations of this is that the pins aren't always in the same place across the different years, and some years don't have a pinout, so it is almost impossible to do one comprehensive listing. I set out to do just that when I was researching my first 4.0 swap, thought I had it nailed, and posted my work as the "definitive answer" to this question. Then I grafted the one side onto my dash harness for the 2.9 and nothing worked. So I started over with a pair of later harnesses and repined an Explorer harness into a Ranger connector, finding it to be the most efficient way to add the wires missing from the Explorer harness. During the process, using three books I found that wires moved around and colors changed. After learning this I quickly pulled down my post intending to try and correct the mistakes later, once I had a working unit. Then mid-project my first kid was born, and I haven't had time to get back to it.
racingranger90
in
91 & 92
ford ranger
can someone give me a pinout like this for a 91 ford ranger with a 2.3L?.. ive been searching all over the web and cant find it.. its the c105f/m connector
3,614
It isn't engine specific.
racingranger90
in
91 & 92
ford ranger
ok, then where can i get a a list for each number like in the pic above where he only has a few... i would like to know what each number is for
