"CaddyShack" Project GO-FER
gwaii
2010 OTOTY Winner
2010 Truck of The Year
66
haida gwaii
460
there is a leak down tester available, must like checking for a boost leak on a turbo car
hey op did you check compression? seems like maybe the rings are worn and you don't have good compression to fire the thing up at all times
leak-down testing on a two stroke is a bit difficult.there aren't any valves,the cylinder is only sealed at the top of the stroke.
bad rings are a possibility.on the crank seals,one end is generally in the transmission,so it will be pulling in oil.if the oil level in the trans keeps going low and there's a lot of oil in the exhaust,this can be the cause.
the other end of the crank has the alternator/ignition on it.remove the cover(on those where you can)and when running,spray a bit of starter fluid in.if the engine revs up,the seals are gone.
mc_muench
"Miller"waukee
ya thanks guys, all good info, Ill hve to check all this when I pull it out if the shed after all the snow melts
Duane867
9
Columbus
2.3L
Check out repairmanualonline.info for your climber repair manual.
I saw one a while back while looking up stuff for my 73' TC100 suzuki and it was free.
TheTopher
176
Delaware
2.3
Good to see ya back at work on this thing, man!
No members online now.
