Call the Ranger abuse hotline!!! 1-800-SAV-RNGR
SMTGREG
MGB
2.3 Lima
I had a customer come in the other day that said he had an oil leak and was using a lot of oil. He bragged that he has spent little or no money on his Ranger and wanted us to look at it because it was raining out. Well I put it up on the lift and sure enough you could see that little had ever been done to his truck.
I have had to replace oil pans in the past for rust thru BUT this is the first time I have ever had to change the OIL FILTER because the Motorcraft casing was rusted to the point of leaking. He said " Go ahead change the oil and filter and by the way here is a coupon for $19.95." I figure it was on there at least 3 years and who knows how many miles.
Has anyone else seen a ranger in danger report them here.
mhughes165
9
302
anytime i see a ranger going down the road that doesnt belong to me i feel its a ranger in danger lol
superds
80
ND
Ford Bronco II
2" body. 1.5" coil spring spacers/rear block
What did the oil look like? Should have saved an oil sample and sent it into Blackstone labs for an oil analysis. Would have been interesting to see what they said the health of his engine.
rusty ol ranger
2.9 Mafia-Don
7,701
Michigan
177 CID
Wow....the ranger abuse hotline people woulda thrown me in prision for how i treated rusty back in the day...i always cheged the oil though...
later,
Dustin
3,614
I saw one once that hadn't had an oil change in about 35,000 miles. I think that may have been the only time it was changed in 70,000. Anyway, the gunk build up was enough that it had managed to get one of the dump buckets off the valve stem and so the cam was pushing right on the valve.
Saw another around the same time, similar oil change conditions but a 3.0. We pulled the drain plug out to change the oil and nothing came out. It showed an ok level on the dipstick, but nothing came out when you pulled the plug.
2 cans of BG MOA and an engine flush later we told them they should probably be changing their oil closer to every 2000 miles.
Junk Collector
Truck of Month
4,861
Rapid City SD
Heh... my buddy's S10 did that the last time I did an oil change for him. I had to poke a screwdriver through a layer of goo to remove the two quarts that were in it. He said it had been about 15,000 miles since his last change but I think it was more like 25,000. He is just clueless... it started leaking oil really bad recently too and he's like, "I need to add oil when the oil pressure gauge drops to zero right?"
'99 EB Explorer
55
Sudbury, Ontario, Canada
LMAO!!! As long as there's a puddle forming in the driveway overnight, that means you still have oil in the pan...carry on with your day! It's when you go to leave in the morning and the puddle isn't there...that's when you have to start worrying. :icon_twisted:
You should've just left the goo IN the truck....that's probably what was keeping it from leaking to begin with. :icon_idea:
My dad had that problem with his transmission. Got it flushed and the problems started coming out of the wood-work. The shop tech told him it was probably gunk that was making it run right and when they flushed it out, that's when s**t started going wonky.
3,614
That does happen and it's why a lot of people are actually against trans flushes.
The thing they don't consider is that if the trans is in bad enough shape that basic maintenance kills it, it probably didn't have long to live anyway.
jhammel85
Guest
Why can't people change oil / have their oil changed....I really think it is my biggest automotive pet peeve..
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
If a transmission is properly maintained, it wont have any gunk in it to begin with. And you certainly shouldn't have to rely on gunk to hold it together. If a trans dies after a flush, it would've died soon anyway. Flushes do NOT kill transmissions. Not maintaining them DOES.
Navyrs
Arlington, TN
2.3
LMAO!!! As long as there's a puddle forming in the driveway overnight, that means you still have oil in the pan...carry on with your day! It's when you go to leave in the morning and the puddle isn't there...that's when you have to start worrying. :icon_twisted:.
Thats what I say about the helicopters I fly in. Its good if its leaking, its empty if it stops. :headbang:
'99 EB Explorer
55
:shok: lol...if i'm ever in Jacksonville, I'll be heading for cover whenever a chopper flies overhead. :icon_thumby:
