cam change in a 93 explorer
stx4.0
I am curious if the cam in a 93 explorer can be changed without pulling the engine?I am assuming there's not enough room but have to find out.
cp2295
7
Washougal, wa
4.0L swap, 8.8 explorer axle, IFS front end
If you ain't first you're last
Pretty sure the only reason to pull the motor is so the oil pan can be resealed properly but rtv should take care of that, just pull the grill and radiator out and then go to work, shouldn't need to pull the motor.
Angie
368
Vancouver area BC Canada
92 & 83 project
4.0L 302
i haven't done it while in truck, but check where the front support is for the cross member is. is it going to be in the way? this would be my concern.
air con? careful of the cooler and the lines, there isn't any play, or give there and will. could be a PITA.
