Camshaft bearing installed wrong?
backerm
Tucson, AZ
2.3L
I took my 4.0L push rod engine to the machine shop and had them install the new camshaft bearings as I always do. So now its time to slide the camshaft inside and the last oil hole is blocked off! Is this really the case, or does the last bearing not have a oil hole?
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,634
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Every journal/bearing gets an oil feed...
  • Like
Reactions: gaz
backerm
Tucson, AZ
2.3L
Yea, after looking at a different angle and a mirror I can see the hole is there. I guess my eyes aren't what they used to be. Thanks for your help.
  • Like
Reactions: gaz
Uncle Gump
Token Old Guy
13,634
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
All good...
19Walt93
4,515
Canaan,NH
351
3"
235/55R16
You get points for checking instead of just jamming it together and finding out later that it was wrong.
