can the 2pc hub & rotor from a stang be swapped
94 lngbd
7
Lakewood,Wa
2.3l
I have a 94 Ranger but I have already swapped the front brakes to the 95 dual piston calipers & outer spindles. I know that the Mustang has the same bolt pattern but they have a separate hub & slip on Rotor. If this could be done it would be cheaper in the future as the Stang rotor is cheaper then the rotor hub assembly used on the Ranger.
Not sure about inner & outer mustang bearings working on the Ranger spindle though.
Any input would be great
97RangerXLT
TRS 25th Anniversary
4,012
Fishers, IN
2"
31"
I would be interested in this one as well... Although I would imagine that for my application (4x4) it would not work... :(
AJ
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
A quick google search on the bearings will tell you the ID of them. You also might have an issue with caliper placement in relation to the rotor...
SVT
