Carb'd 2.3 to 2.3T
NightRanger96
Salmon Arm, BC
Hey all,
I did some searching on here and Google, but couldn't find anything super specific on my topic.. I apologize in advance if there's a glaring thread that I missed :p
I managed to pick up an '87 T-bird TurboCoupe with 5 speed. The wiring is all in great shape, but the body is toast so I'm looking to transplant everything into a Ranger. I'm partial to the classic look of the pre-'89 models, and I've found an '88 single cab that's in great shape.. Apparently in Canada, our trucks could have the carbureted 2.3 up to this year, and this one has it along with a 5 speed.
I'm wondering if anyone on here has swapped the T-bird drivetrain into a 2.3 carb truck and if so, what wiring changes need to happen? Or would it be best to scrap the carb wiring and just move all the T-bird wires over? I'm not planning on anything too crazy - just a nice rebuild to get the engine running smooth again.
Great forum - been learning lots on here! :headbang:
Reed
NightRanger96
Salmon Arm, BC
Did you have a look here: http://www.therangerstation.com/tech_library/index-engine-fuel.shtml
Under turbo & supercharger section.
T-bird turbo in ranger was a popular swap
I did. It appears as though most of the articles for turbo swaps/wiring changes are for Rangers with EEC-IV (I'm assuming the carb'd 2.3 didn't have a computer?).
I'm more looking for input on what needs to be changed in the carb'd truck.. And more and more it's looking like everything needs to be moved over from the T-bird!
8,372
Yes, computer and wiring from the T-bird has to be moved over to Ranger, so Ranger computer model number or wiring wouldn't matter, it can't be used.
Main use of computers in vehicles was limited to air/fuel control for better MPG and emissions, carb or fuel injected, for carb it was optional, for fuel injection it was required.
Transmission control was added for automatics in the mid-80's, but as long as you stay with a manual trans you are fine.
Turbo also used a few different sensors like the Vane Air Flow sensor, it was used to calculate 14:1 air:fuel mix based on air flow, similar to MAF sensor but mechanical vs electronic.
MAP sensor was also used so I believe computer was running Speed Density software as the base, but not sure on that.
In any case a 2.3l computer can't be used with a 2.3l turbo engine without major programming changes.
NightRanger96
Salmon Arm, BC
My T-bird tranny is manual and the truck is manual as well, so should be a seamless transition.
I was looking at it today, and it appears the only thing that would need to change is the fuel delivery system on the truck.. Does this sound right? Find a tank and lines from a fuel injected Ranger for the carb'd truck?
