Catalytic Converter rattle
DBCcatcher007
Just got some Flowmasters put on and now the catalytic converter rattles and is ruining the sound. The rattle is coming from the first catalytic Converter. Since I can't just crack it open, what could I do to stop the rattling?
85_Ranger4x4
17,908
SW Iowa
Replacing it would be the easiest.
turbo cat
city of rain wa
exploder
4.0ohv turbocharged
check to see if the heat shield is loose and if that fails you can unbolt and drop it down to see if you can see whats rattling inside
rickcdewitt
5
nor-cal
4-0 swap
i bet its the heat shield,wrap a big hose clamp around it to shut it up,worked on my truck
84projectFORD
Phoenix, AZ
yeah chevk the heat shield. if its not that then most likely the cat is shot. i have DPS crown vics come in for the same thing. if you leave it alone then eventually the plate inside will actually plug part of your exhaust and cause you to lose a good amount of power
bottledgt
get rid of it and sell it
IDontCare
Fresno CA
i cut the heat shield off.... it already had a close hanger tied around it
11
85_Ranger4x4
17,908
SW Iowa
WhiteBroncoII2WD
Delaware
check the heat shield for starters...was it rattling before the Flowmasters were installed?
BlackBII
Ranger Custom
Truck of Month
982
UT
My guess is heat shield also. Do the try the Hose Clamp idea, worked on two of my trucks.
