nola mike
- Jun 4, 2009
- 0
- VA
- Ford
- Engine Size
- 4.0L V6
Have had intermittent issues with the last 2 codes (banks 1&2 too lean) triggering the CEL. Got a fancier scanner to do some more diagnostics, and noticed the first code now also showing (EGR flow excessive). All of my fuel trim codes (SHRTFT/LONGFT) are at -100. All of the O2 sensors are showing 0v (from the scan tool, not directly measured). Looking around, it seems that a bad DPFE will throw these codes, although it looks like more often it's too little EGR flow. So, here are the questions:
1. Could a bad DPFE (or stuck open EGR valve) be the culprit here? would too much EGR flow result in lean conditions?
2. Are my FT and O2 sensor readings just indicative of the engine attempting to maximally enrich the mixture, or is there a problem with the O2 sensor signal to the computer? Of note, when watching the live data, I get no voltage fluctuation at all, even when engine is cold (it should be in open loop, right? not at 0v yet...) or with changes in rpm.
any other thoughts?
any other thoughts?
