Center Caps?
afbryant1964
laurel hill nc
Hello again guys, I have a 95 2wd and I would like to find some center caps for it . I don't know these are the original wheels or not. I know that they do not have the 3 screw holes for certain caps. I don't know which caps to get for it. I think the wheel number is #3184. Help me figure out which ones will fit. They are 14s
tinman_72
137
North Georgia
2.5 (4 Cylinder)
2.5
Factory
None
255/60R15
RoHS compliant
Those are factory Ford wheels commonly called "deer hoof" wheels. Ford stopped using the center caps that screw in to the three holes after the '94 model year. In '95 they starting using center caps that are a little more rounded and pop on to the lug nuts.
I would go junkyard hunting if I were you. I have seen aftermarket reproductions for crazy amounts of cash. You could almost buy a new set of aftermarket wheels with center caps.
Ranger850
Doesn't get Sarcasm . . .
4,696
Tallahassee Florida
Stock 2"
Stock
You need the special gold colored lugnuts and the weird bubble looking center caps that snap onto the golden lugnuts
afbryant1964
laurel hill nc
Thanks for the help guys. What is the name of those special lug nuts? I was sorta wanting to find the caps like the picture that I am posting. So, I assume that I wont be able to use these because mine do not have the 3 screw holes?
Ranger850
4,696
Tallahassee Florida
Stock 2"
Stock
Unless you want to drill the holes yourself. Then run some self Tapp screws in there to hold them down
Or you could use those plastic drywall anchors and just cut the to fit. Don't know how handy you are, but anything can be done, and those would be unique if you did it.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,535
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Danno1985
105
MKE, WI
stock
stock
stock
I love those classic Ford caps with the split red centers. I picked up a set and plan on drilling my steel 15x7s to make them work, but in the meantime I actually found a set of the appliqués on ebay and put those in the centers of my stock caps. I like the look. Note - you'll need special "collared" lug nuts to run the snap-on type center caps.
26097
Mike Tonon
Guest
Bare in mind, the holes for the screws were not just into the rims. There was a large hole in the rims that a little bracket popped into, that the screw went into. I don’t know why Ford did it that way. Maybe if you put the screw directly into the rim, it’ll seize??
pjtoledo
2,992
Toledo Ohio
Fords
3.0 2.3
early Taurus' did that too. using that plastic insert seems to work quite well.
racsan
4,497
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
pjtoledo
2,992
Toledo Ohio
Fords
3.0 2.3
TiaRosa88
Iowa
Hello! Mike Tonon mentioned a bracket that goes into the rim and then the center cap screws into that. I have a 1987 ford Ranger. Does anyone have a picture of said bracket?
James Morse
1997 XLT 4.0L 4x4 1999 Mazda B3000 2wd
974
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
4.0L in XLT, 3.0L in B3000
31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
The perfect is the enemy of the good.
op has original 'deep dish aluminum' wheels aka 'deer hoove'
I think they would want the normal oem covers for them that attach to the lug nuts with 3 clips. don't know if op's vehicle is 2wd or 4wd, if 2wd then they'd be the same all around, I believe. 4x4 of course the fronts will have a cutout in the center for the hub. pic of mine, could also check out the sales brochure for op's year here on TRS. They should be available at junk yard? I'm puzzled by screws etc it doesn't apply at least not oem afaik. One of the lug nuts looks not oem, the clips could still go on 3 others as long as that one clears but you should be able to get lug nut too I'd think. ebay has caps, repros $60 a set, or originals if you want to pay more for the latter. they dress it up substantially, remember, wheels/tires are 40% of the appearance.
