changing tire size for towing
racsan
4,522
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
what tire size would effectivly turn my 3.73's to 4.10's? seems a set of tires/used rims would be a way to go rather than spend time/money on a gear change, and if it doesnt lead up to expectations its quick and easy (in comparison to a gear change) to change back to stock size tires. or would it just look stupid having tiny tires in wheelwells that had 235-15's stock ?(and 265's were a factory available size). im not sure if 4.10s would be enough and 4.56 is quite a jump. (plus you know id have to put a lock-rite or detroit locker in there while im in there)
________
Plymouth Pronto
tanbuddy
Poconos, Pa
2.9
Whats your stock size? 235 75 15? Thats about 28.9 inches tall with a 3.73 gear. To make that equal to a 4.1, u need a tire 26.3 inches tall. 195 75 15 is 26.5 so thats about as close as ur gonna find.
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
Hrm, Interesting approach.
racsan
4,522
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
i'll probly change gears eventualy, but this way i can see if it will be worthwhile before all the time,$,& effort. having 2 differentials makes for a costly ratio change. or i could just run small rears and not use 4wd when im needing to use the trailer. probly just put a lock-rite in the rear, less stress on the front u-joints is always a good thing, took me most of a day once to change the steering u-joints (a good part of that was just getting the spindles out of the knuckle) yes 235/15's are my stock size.
________
vaporizers
jtfoxman
Poconos
That would be some pretty small tires on there. Is it actually worth it?
dogboy
14
Enumclaw/ Carbonado, WA
'93
I don't know if this applies to Ranger T-cases, but when my dad had our Sami, he didn't mess with the axle gears at all. All he did was put a reduction in the transfercase. Does the same thing as far as I know, and is cheaper than doing the axle gears. Or at least it was when we did up our Sami.
Will
TRS 25th Anniversary
514
Gnaw Bone, Indiana
Toyota
It works. If you need the power, go for it. A 205/75-15 was what came stock on most earlier 4x4 trucks.
