Mechman98
- Dec 26, 2010
- 0
- Ford
- Engine Size
- 2.9 L V6
Looking to get some of your opinions on some electrical issues with my 86.
Thus far I have traced it down to the charging circuit I think - if the alternator is connected (Y/W - B/O - LG-R wires) near the master engine misses consistently at idle (hot and cold, worse when cold) and stumbles to death (won't rev over 1200-1500 rpms) with the tach bouncing on every miss. Engine misses even worse with headlights or heater on. Unplug it - runs like a top no misses, plently of power until voltage drops from the battery not charging and the truck dies.
Alternator is new and wiring seems to be ok from the alternator to the connector, and then into the cab. Got continuity from the connector to the instrument panel connector for the ammeter, checked black/Orange to the fuse panel, and yellow to fuse panel and ignition. Dash lights seem ok brightness wise. Ran another ground from the battery to the dash ground under the column but haven't noticed any improvement.
Not sure where to look next. Replaced headlight switch with a good spare, multifunction and wiper switch. Ignition was not replaced, connector is clean and tight. Wiggle tested (coneector and key) with no issue as far as I can tell. I have the wiring diagrams and have been trying to go through it connection by connection without much luck
Any ideas are appreciated - Thanks
