Check engine light is coming on randomly and then goes off
black_demon69
142
AZ
4.0l
Finally got a chance to swap ecu and so far light is off.
I will update tomorrow
black_demon69
142
AZ
4.0l
CEL comes back on will pull codes tomorrow
black_demon69
142
AZ
4.0l
OK finally got time to pull codes after putting original computer back in.
Codes
522
539
522 (O) Park/Neutral Position (PNP) or Clutch Pedal Position (CPP) circuit fault Transmission MLP sensor out of range in park
539 (O) System shows voltage at PCM pin 10. Is A/C on ?
black_demon69
142
AZ
4.0l
Just an update
CEL has stopped coming on with the exception of the self test when ignition is turned on.
It kinda fixed itself I never could find the problem because I couldn't catch it with CEL on so I could pull codes while it was running.
My theory is that something was sticking to the o2 sensors and finally burned off but again I don't know what it was for sure.
So what do you think was going on?
