Chevy 63 & 64 Inch Leaf Spring Clarifications....
PlumCrazy
2014 Truck of The Year
179
Millersport, OH
Solid Axle Swap 4x4
Did you have extended shackles with the 64" leaves?
I wasn't able to ditch the stock block until I swapped in 5.5" Chevy lift leaves, and I still have a 3/4" block even with extended shackles. But I am between 5-6" of lift with a little rake to it.
-PlumCrazy
xBLAKEx
Paradise, Ca
1988
4.0L, 2.9L V6
Hmm doesn't look to promising then, for what i have. I have belltech shackles, nothing fancy like revolvers. When i did this swap on my 88 ranger i kept the stock 4x4 block in, so i guess i could just do that again. The other thing i was thinking about was mounting the leafs under the chassis, but I'd have too move the spring perches in.
xBLAKEx
Paradise, Ca
1988
4.0L, 2.9L V6
Are there advantages or disadvantages of moving the leafs under the chassis and perches over, or just leaving them where they sit now and build new mounts lower?
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
The leaves will flex easier with them inboarded but you will give up a bit of stability.
red_ranger50
4
Diamond springs Ca,
4.0ohv
1.25in
I read a lot of this and I'm curious. Can I use my stock ranger hanger and rear shackles for the 63/64 leaf swap? I looked at the swaps on the tech library. and it looks like they reuse the front hangers am I mistaken or are they using ones off the chevy or the ones off the ranger?
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
Just relocating the factory hangers.
Sent from my DROID RAZR using Tapatalk 2
alwaysFlOoReD
5,197
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
88-00 http://65.61.38.85/dpweb/App_11/dist_site/215/STRK1_0H_print.asp?Section=CHEGMRC3&SubSection=A&Make=GMC/Chevrolet&OEM_Code=CHE&RecipeID=STRK1_0H&Cat=3L&Figure=22-797&Point=</span>
99-13 (Except 11-13 HD) http://65.61.38.85/dpweb/App_11/dist_site/215/STRK1_0H_print.asp?Section=CHEGMRSIL&SubSection=A&Make=GMC/Chevrolet&OEM_Code=CHE&RecipeID=STRK1_0H&Cat=3L&Figure=22-797&Point=</span>
Figured I'd post this. I sell OEM style 64" springs and all other stock height springs for any LT (light truck) The above link is for springs available from 1988-2013
There is NO SUCH THING as a chevy 63" spring in any of my catalogs. There was a 54" and a 56" available from 1973-1987. From 1988 + they were all 64" leaves.
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
People interchange 63 and 64. Unloaded they measure 63ish
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
understandable, I'm just saying, the proper length is 64
UrbanRedneckKid
17
Cass Co, Missouri
People don't know how to measure a leaf spring. I've argued the 64" measurement on here till my fingers were numb, one idiot following another... Kinda like the members, and Craigslisters, that say they have a 6.5' bed...
98Ranger702
I'm more concerned about have a decent amount if travel and a smooth ride put in the dirt..
From what I've read the 1/2 ton leafs and flipping the shackle will accomplish this? How far back will I have to move it to gain more travel an less lift?
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
Everyone has slightly different final ride heights when using used springs....sometimes you just have shoot from the hip and try it.
red_ranger50
4
Diamond springs Ca,
4.0ohv
1.25in
Awesome thanks for the clarity guys. I'm getting g ready to do the swap I have a friend who's going to modify my camburg rear shackles to fit the extra girth of the Chevy leafs and cab up some new brackets on a new explorer axle. I'm pretty stoked.ha
alwaysFlOoReD
5,197
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
There should be NO extra girth. The stock chevy springs and the stock ford springs are both the same width, IIRC - 2 1/2" I didn't notice any difference in the size of the end wrap either.
Richard
No members online now.
