Cleaning IAC on 2.9L??
ab_slack
12
New Joisey
2.9L
I came across some instructions that outlined how to clean the IAC valve. Seems simple enough.
I have a vague recollection of someone saying not to clean the IAC for some reason. Or to be careful to not get cleaner in the IAC while cleaning other parts.
In my two week survey of sensors and controls this is one I haven't touched yet and want to make sure I understand what I am doing before I mess with it.
Thanks.
8,372
The IAC(idle air control) valve is used between two air passages in the throttle body, one on the air filter side of the throttle plate and one the intake side of the throttle plate.
It is in essence a controlled vacuum leak.
It has a small plastic or metal cap, this is for pressure equalization not for air flow into intake, it makes it easier for motor to move the valve when vacuum is high on one side.
It uses a Step Motor, a brushless electric motor that converts digital pulses into mechanical shaft rotation, this allows computer to set and return valve to pre-set positions based on learned values.
After removal you can just spray cleaner into the air passages on the valve and let it sit, then clean it out.
Before installation connect it to engine harness and turn on the key, assuming engine is cold IAC valve should open all the way.
ab_slack
12
New Joisey
2.9L
Sounds good and simple enough. Thanks for jumping in on my much of questions today.
Ford tells us not to clean them because it can knock loose a piece of carbon or dirt that can jam the plunger and make it stick worse. I won't clean them on customer's cars for that reason, but on my own stuff it's worth trying to clean it first.
8,372
Yes, but Ford also recommends you trade-in your vehicle for a newer model if the windshield gets dirty, so........................:icon_rofl:
Yes, shop mechanics have to work within a different set of parameters than DIYers do.
When you have to guaranty the parts and labor, you can't do the "cheap" things "to see how that works".
