Clearancing passenger axle window?
Freshmeat
40
Denham Springs, LA
Tearing down my D35 for some maintenance and wanting to do all I can to get the most out of it while it's apart. I have searched for over an hour but can't find any detail on clearancing the window other than pretty much everyone saying they've done it. Can someone help me out with a link here? I'd really appreciate it.
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
There's not much to it really...
I took a grinder and just stuck it in there making it wider up & down, then used a Dremel to kindof clean it up afterward.
Here's a pic:
Freshmeat
40
Denham Springs, LA
I dig it. Thanks, man. Is that a limiting cable attached at the sway bar bracket?
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Yeah, I put a cable over the frame to limit the amount the suspension unloads on steep climbs, while still allowing the full amount of flex (same exact principle as a "center limit strap" or hooking your winchhook to your axle).
i dont see any pics
:dunno:
Try clicking here, the pic is taken from that thread.
