jballard81
- Feb 24, 2024
- Reaction score
- 160
- Location
- North Carolina
- Make / Model
- Ford Ranger
- Automatic
94 ranger, dash wasn't lighting up on the tach side. so pulled it apart and replaced the 194 bulbs.
I initially replaced them with LEDs, which was a bad idea. but plugged it in, and turned the lights on and all of them flashed on then turned back off. So it was at least working at that point.
realized the error in my ways and replaced the LEDs with standard long life Sylvania bulbs. plugged it in and turned on the lights and now the cluster lights don't work at all.
key on will light the other bulbs at the bottom of the cluster.
pulled the cluster back out and tested the lights on the bench (with a 9v battery) and they worked. i traced the flexible printed circuit and i see continuity from one plug to the other.
i checked the 10a fuse and it tested fine.
i cleaned up the printed circuit contacts where they are plugged in and the connectors themselves and still nothing.
any advice on further trouble shooting? It 'feels' like a connector issue, but it's weird that the other dash lights still work in that instance.
*Edit* just realized i put this in the wrong section. my apologies!
