Clutch noise (sounds like im barking the tires)
chasemyranger
in washington, by oregon, but not really
3.0/460/302
My truck with just over 110,000, and a manual 5spd tranny, started having a transmission/clutch squeak last summer, and if it happens it is only when i am taking off. My dads semi trucks don't do this, my other truck doesn't do it, and well i haven't really heard it at all before, it sounds very much like im peeling out, but it is higher pitch and just makes you hurt inside if you know what i mean. Another thing i have noticed is downshifting, along with the noise, downshifting into first is getting worse, i know it is hard, but it has more recently started to grind the gears, something it has never done, as if im not using the clutch at all, even when its on the floor, but i know my dads semi trucks are like this, as well as my other truck, which has a brand new clutch in it, however it is an older truck, 1976 f250 w/460 4spd. From what i have read it may be my throw out bearing, however im not sure about the whole thing, and my dad is not helping me, just saying that i probly am peeling out, and for the record i know im not. So if you have had this problem, and have had it resolved, or know a little something about it i would love to hear from you,
Thanks, Chase
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
I'm going to guess you have two separate issues.
The grinding gears is probably the clutch not fully releasing (often caused by a leaking slave cylinder. Check your clutch fluid reservoir, if it's empty, you got a leak that's allowed air into the system, preventing it from releasing fully).
As for the squeak or squeal, the clutch in my BII did that when I first got it (did it mostly when it was cold IIRC). Never caused a problem driving it though. When I swapped the clutch out (2.9L to 4.0L clutch swap), nothing looked wrong with it that I could tell. :dunno:
Gary101386
Oswego IL
2.9
mine does the same thing... i cant seem to figure it out either...
Kcameron13
Farmington Hills, MI
4.0 OHV
My older ranger did that for awhile, turned out to be the throwout bearing. Worth checking into.
