clutch or synchros?
Nehring13
Waterford, Wisconsin
hey all, i just had a quick question.... i have a 98 ranger, with a 5spd, sometimes my trans doesnt want to go into gear, it just wont go in, its like theirs a stopper on it and wont let it go into gear, its my synchros not my clutch right?
Bent Bolt
4
Edmonton,AB
Supercharged 4.0 SOHC
Solid Axle Swap 4x4
As you try to push your shift lever into 1st gear ( while vehicle is stopped ) reach over and shut the engine off. Does the lever go into 1st ??? It's most likely the clutch slave cylinder.
racsan
4,528
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
could also be the input shaft hanging up on the pilot bearing.
________
justin bieber fan
Nehring13
ill try that, and let ya know. thanks
