smegun
- Jul 16, 2019
- 0
- florida
- ford explorer
what can i do to improve the vacuum advance ? new lower intake manifold gasket new head gaskets newer brake booster new relays ...air intake check good air box is ok .... im beeping out the cabin 60 pin connector for the pcm and ive got a lot of beeps when doing continuity from the point of pin 58 and 59 like :/ this guys diagram doesn't have the 94 sequential right he is using the 93 and earlier pined out I had to fiddle to make preparations to beep out the harness im still looking for a proper procedure since there are a lot of beeps and im trying to determine if i got a short ...... p spice for pin 46 ??? bummer tps is on that line ..... also notice the tan wire for the injector(s) pin 58 there are two injectors on it so only 5 are in the diagram to individual pins ? .......................im dreaming of error 538 with fuel uno dos tres quatro cinco senquencho not sure i want to understand but since its from originally a two bank system ??? but im rich somewhere with new injectors the old ones were doing it too .....there connector has room there is probably base address for the pins they didnt sign it up on its own Flag in the program ???? what reason .6 pi formula irregularity timing problem ?
wot wide open A/C cutoff ? I do have the dryer and the highpressure line and compressor out of the vehicle but i dont want to know what your thinking wrong relay ?
