Cold air intake
Terry
19
Gardnerville, Nevada
Does anybody have a real aftermarket air cleaner assembly home made or store bought? The ones that I keep seeing have a cone shaped filter on a pretty polished pipe but the setup really does not pull in cold air it circulates engine air. I will build one myself but I would like to see your ideas.
cammeddrz
23
Ford/chevy
efi 350vortec
the stock air intake is a cold air intake
the 2.9 airbox pulls air through a hole in the inner fender, and depending on the year of rbv it even has a duct that routes it to the front and pulls it through the grille
any of the aforementioned aftermarket clamp-ons, on a polished tube are a hot air intake
if you have the ambition you could do what i did, i made my own with dual clamp ons, a fabricated air box, and a cowl hood.
Terry
19
Im thinking about pulling the air from the same area as the stock cold air box. I need to figure out the tubing. I wonder if you could modify the stock air box for more flow and a cone filter?
cammeddrz
23
Ford/chevy
efi 350vortec
just get a stock replacement high-flow filter, put it in your airbox, and be done
Bob Ayers
16
Durham, NC
Don't waste your time. The stock airbox & filter will flow more air than your engine can pull.
cammeddrz
23
Ford/chevy
efi 350vortec
^^ *sigh
the debate between high-flow filters vs. paper filters rages on.......
yes it will flow as much as the engine needs, but at what rate of resitance?
the benefits seen on a high flow filter isn't to get more volume, but more to get the same volume at less resistance
any resistance that an engine sees will equate to a loss of power.....that's just common sense
Bob Ayers
16
Durham, NC
^^ *sigh
If you put a vacuum gauge on the OEM intake tube at 5000RPM, and WOT you won't measure any vacuum. Therefore, the OEM intake / filter IS NOT the limiting factor for air flow. This throws your resistance theory out.
cammeddrz
23
Ford/chevy
efi 350vortec
i think you should be using a manometer not a vacuum gauge
a vacuum gauge isn't precise enough to measure the difference made
a person who has ever done it, or even knows what they are talking about would know that
cammeddrz
23
Ford/chevy
efi 350vortec
and to be clear any resistance an engine sees will equate to a loss of power, that theory is sound, and really can't be thrown out
Bob Ayers
16
Durham, NC
Ok, one more time......take a look at the diameter of the throttle body plate, and then took at the area of the OEM paper filter. And your still going to tell me increasing the area of the OEM paper filter is going to make any difference?
Bottom line, the OEM paper filter IS NOT going to be restrictive to air flow!
Because of CAFE standards, auto manufacturers don't design intake systems to be inefficient! The reason for the small diameter throttle body plate, and intake runners is to increase the air velocity entering the cylinders via the intake valves.
fyre82
Firefighter
6
Lake Almanor, Ca.
2.9/4.0
9" on the 2000, 6" on the '88
265/75/16, 31x10.50x15
The memories of a man in his old age are the deeds of a man in his prime
And the debate rages . . .
Anyway, I did something similar to what you are asking about.
I also added the larger throttle body recently.
With that set up, my 2.9 is boggy until it warms up but runs fine otherwise.
What I did increases intake sound considerably but gives it a nice growl from inside. As far as performance? Eh, who knows, it never was one to set you back in the seat on acceleration . . .
The write up is behind the first link in my sig, page 4. Nothing fancy, it works and was done at a very small cost.
Rich
