common rail conversion ?
24v or CR
  • 24v
    Votes: 2 50.0%
  • Common rail
    Votes: 2 50.0%
  • Total voters
    4
twoll86
U.S. Military - Active
9
caseyville,il
ok im looking @ buying a 01 ford excursion with a 5.4. i am wondering what i will need to do the common rail swap with an allison and the ford trans or 2speed atlas. or would i be better off doing a 24v swap with the allison? is one engine better than the other?
superds
80
ND
Ford Bronco II
2" body. 1.5" coil spring spacers/rear block
Which engine are you referring to as common rail? There are many common rail engines in existence.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
i would use a 12v complete mopar powertrain fan to t case outputs.
if your stuck on the allison, its easily incorporated.
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
Most people mean Cummins when referring to light vehicle applications.
I'd go 12 valve/NV4500 personally.
superds
80
ND
Ford Bronco II
I figured that was the case but wanted to make sure.
twoll86
9
caseyville,il
yeah i ment the 03/04 cummins engine
MountainMike
84
Canada
245 CID
2"
31"
The fun begins where the pavement ends
hondarider552
Carefull with the allison, you will need a stand alone controller from TCI in order it to talk to the dodge ecm and ford dash guages..
84projectFORD
Phoenix, AZ
and even then you will still get funcky shifts or defuels. IMOP you better off with the dodge trans in there, jsut get it built.
BTW Common rail and 24v are the same thing on 03-up dodges.
