- Dec 4, 2007
- 0
- Age
- 37
- wausau, wi
- ford
- Engine Size
- 5.0 h.o.
alrite so im in the process of putting the 87 ltd roller motor in my 85, but the problem is that i cant get a power steering pump bracket to work because of steer gear clearance issues. i finally found a bracket from march performance that clears the gear, but it mounts in a way that the belt wont run on the water pump. so i was thinking of doing the non rib pulley conversion on the water pump, and the problem is that i know that without a non ribbed idler mounted on the lower driver side, ill be spinning the water pump in reverse. if anyone knows how i can fix this or get an idler mounted please chip in. thanks in advance
