- Mar 4, 2010
- 17
- Omaha, Ne
- Duh
- Engine Size
- 5.0L, 2.9L
Changing the water pump on your truck should be fairly simple. About the hardest part is remvoing the fan clutch and fan. You will also need to drain the coolant. If you drain it in a nice clean container and it looks good you could prolly get away with reusing it. When I did the one on my 2.8 I didn't break any bolts.How hard is it to change a water pump on this? Like is there anything I should really worry about, like breaking bolts or anything like that?
Sent from my VS910 4G using Tapatalk 2
Just take your time make sure all surfaces where a gasket goes is clean.
Sent from my B2
