- Aug 7, 2007
- 540
- Costa Mesa, CA
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0 SOHC
- 2WD / 4WD
- 4WD
- Tire Size
- 33"
Last weekend I did some work on my Ranger that I had been wanting to do. One thing was installing an aluminum thermostat housing. I had a couple typical issues with this install. One was the holes for the sensor and sending units were larger than stock and I had to find larger O-rings. I could not find any that looked suitable so I took ones that were too thick and sanded them down in a lathe to a size that worked.
The biggest problem was electrical. Initially the temperature gauge would not work, it just stayed on C when running the engine. With some investigation, I found the connector was bad. Apparently, it got damaged during the install. I ordered a new one and installed it. I tried to connect the wires the same way they were, but I was not that careful since I read somewhere the sender was just a variable resistor and it would make no difference which way it was wired.
Once installed, I started the engine and waited for the gauge to come up. It did and I took it for a drive. The needle got up to the normal position at just below half way. After about 10 minutes, the gauge suddenly went to H. I began pulling over and it went back down to normal. It continued this up and down maneuver and I eventually got off the freeway. When I checked the engine, I could tell it was not over heating and thought it was just a bubble in the cooling system from refilling. I continued on and eventually added more coolant, but by then the gauge was way past H at full lock and would not come back down.
When I disconnected the connector from the sending unit, the gauge would go back to below C with the ignition on. Connecting would send the gauge back to above H. I was baffled, because if there was a short in the wiring it should have stayed above H when disconnected. I got out my multimeter and started investigating. I could tell the sensor was still good but I had no values to know what is good on all the other readings I got. I began to suspect the new connector and cut the wires to check. It was good too. I tried changing polarity on reading the resistance on the wires that go into the loom. I found slightly different readings and decided to try connecting the wires to the sensor in reverse of what I did originally.
Reversing the wires resulted in the gauge going to C with the ignition on and the gauge continued to operate normally on a long drive. So, apparently it does make a difference as to how they are connected.
The mystery is, why did the gauge work correctly for a short time with the wires backward and then suddenly go bad?
