Couple of computer ?'s
1RangerNut
Central,IL
2.9L
First can you swap one from a manual vehicle and put it in an auto?
Second what are you off road guys doing to water proof them?
1RangerNut
Central,IL
2.9L
She got a little wet on the 4th...
Hoping it's just the computer that's messed up cuz I just put this motor in and it was running great. But knowing my luck I'm sure I screwed the motor up... :sad:
8,372
If it sucked in water then yes, motors got a bent Rod and/or broken piston
Google: hydrolock
And remove all spark plugs before trying to crank engine
You need an auto computer if you have an auto trans, computer runs the torque convert clutch(TCC) and the shift to Over drive(3-4 shift) on automatics in '89 model
1RangerNut
Central,IL
2.9L
What if I'm only using 1st and 2nd will it run the motor correctly?
And crap it definitely got water in it, this pan was empty when I started.
8,372
I meant if engine was running and it sucked in water thru the intake and into a cylinder, if that happens engine stops suddenly because water doesn't compress like air does, so connecting rod bends or piston breaks, or both.
The milk shake means water got into oil pan and most likely was circulated thru to the bearings, not a good thing but running clean oil for 100 miles then changing it, and filter, again would clean it out.
1RangerNut
Central,IL
2.9L
I was in it trying to make it through when it shut off
Kirby N.
Truck of Month
78
Monument, CO
An auto computer will work in a manual, just not very good. The manual has different idle settings for when you are moving to help you shift etc. I think timing may be different too. I did a manual swap on one and ran an auto computer until I found a manual one
1RangerNut
Central,IL
2.9L
After all the messing around and swapping parts I had 5 and 6 wires on wrong... Stupid Me
Does anybody have any input on waterproofing the computer or are they?
And would the manual computer have a higher idle then? Cuz that would probably actually help off road.
