Socket on a breaker bar laid over to rest on the frame, then bump the starter. Unplug your coil packs first if you're using the key in the ignition switch.
keep the belt on the acc. on the motor get a 1/2 inch ratchet or breaker bar and turn it to your left as looking at the bolt if all else fails remove evrything out of the way and get impact or try above post very carefully
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
