I like it! Needs some bigger tires though!
What cb radio is that? It fits perfectly in the ash tray. And how do you like those spyder foglights?
Couldn't agree more on the bigger tires! I'm thinking 33"s after a 4" lift and a 3" body lift... (Yes, I know that's excessive for 33's) That's all I really want to do to put lift in a 2wd (Yes, I know I have locking front hubs, a 4x4 switch, and a 4x4 sticker on the truck.... they're on there as a joke)
The cb is actually insanely old but hey, it works just as well as any of the new ones and now that they're so old they're cheap! It's a cobra plus. It fits in there but it was a bugger to get the mounting right for it. Ended up cutting up and making my own mounts instead of the simple bolting in that they usually take but the better look is definitely worth it!
I flat CANNOT stand the foglights!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
They come with super cheap seals on them and fill with water when you wash your truck. Then you pull them apart, clean everything, and seat the seals the way they should be. After that the seals slip forward again and let mud in when you're playing in puddles. So you disassemble again. After doing this a few times you seek out other ways to seal them. I used silicon which actually worked pretty well for a while. But then I went mudding again and they filled with mud! Now the passengers side is dim and the drivers side won't turn on so I've left them for now... I'm pretty sure the drivers side is just water that got into the connector and pass side is a dirty lens but still... I wouldn't recommend these.
That being said - They do look great with the halos on and, after you grind the little beam deflector tab off, they throw a decent amount of light. I think next time I rebuild them I'm going to throw 100w h3's in and seal the crap out of them. Then we'll see if my opinion of them changes
