crown vic suspension swap?
twoll86
U.S. Military - Active
9
caseyville,il
has any one used the late model crown vic front suspension( hole cross member and all) in a 88-97 2wd ranger to get rid of the factor style suspension
JoshT
1,885
Macon/Fort Valley, GA
Pretty sure it's too wide. Folks use it for the full size trucks.
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
654
Central Indiana
A quick googling shows the CVPI track width being around 63 inches. Don't know about the squarebody rangers, but 93+ Rangers have a track of 58.5 inches in the front. If anything, the squarebody trucks may be a bit narrower than that, so the CVPI swap would probably be 5-6 inches wider than your current front suspension.
If you want to ditch the ibeams, and switch to control arms, you can try 98+ Ranger 2wd clips, 90's toyota truck clips, or Mustang II clips. The bagged guys do clip swaps quite a bit, and those are the 3 most common donors.
Or, AJE just started selling a bolt-on kit to use a foxbody mustang k-member setup in i-beam Rangers. I don't see it listed on their website yet, but I've seen it on their facebook page. Looks nice, and supposedly takes a couple hundred pounds out of the front end. Also allows you to easily use anything (suspension/brakes/coilovers/bearings/rack and pinion steering/etc) from the massive Mustang aftermarket. Here's their website with contact info: http://www.ajeracing.com/
tsi617
From my research, 83-97 frames are similar in build, which leads me to believe they are the same. People do cab/frame swaps with no frame mods.
Sent from my XT1080 using Tapatalk
twoll86
9
caseyville,il
Can you share a link to thier fb article on it? I know that suspension well since ive built numerous fox bodies
twoll86
9
caseyville,il
Well if i can get the aje kit reasonably ill bo that route
stmitch
MTOTM Winner
654
Central Indiana
There isnt a single post with all of the info and pics, so you'll have to dig around to see more, but this should get you started: https://www.facebook.com/AJESuspension/posts/10152540775956817
Looks like $1900 for the k-member, strut towers, tower brace, lower control arms, and coilovers. More for spindles, brakes, and rack and pinion steering kits.
rab
merkur
I have seen people section the CV front suspension also.
I'm thinking of doing one of these swaps myself, I would like to know how the stock 98-up ranger stuff really is compared to let say the CV stuff or stang2 stuff.
