cummins Ranger???
primeevil27
Edmonton AB.
does anyone out there have any info on what i can do to squeeze a 4L $BT Cummins into my ranger??? it is supposedly 36" tall and 26" long, and about 18" wide or something like that. I have a 3" body lift on my 93 ranger 4X4 The crank to top of engine measurement is about 24".
Thanks for your time, and input.
Kelsy
PARKINGLOT
St. Thomas, ON
Jeep
5.2
I've seen 2 done, one into a first gen explorer, and one in a first gen Bronco II...the bronco has video's on youtube.
baddis
6
Avon,il
2014
4.0 Sohc 1.5 ecoboost
check out 4btswap.com or mooktank.com
DieselSmoke
WA
www.overlandvans.com/0104_diesel.html
has this info
The 4BT 3.9 engine is rated at 120+ hp @ 2500 rpm with peak torque of 327 lb-ft @ 1700 rpm. The engine weighs 570 pounds (dry). The 4BT 3.9 engine dimensions are...:
Total height: 30.6 inches
Total length: 30.1 inches
Total width: 22.9 inches
www.4btswaps.com/
has some other stuff on it
Ozwynn
200
Berrien Springs, MI
RE Interceptor
there is a guy that built a header for it that got it to 136 hp, increased boost, and lowered the egt. but I lost his build up since i reformatted......... but it was a gen3 and uses a 14 bolt in the back and a D60 in the front. I have seen 2 LandCruisers with that swap..... 1 with a TH700r4 and the other with an NV4500 .......... both transmission the gear spacing is too wide so you might want to run a gear splitter with it.
primeevil27
Edmonton AB.
i was thinking of going automatic, with a c-6 and a different transfer case too. not too sure what you were talking about with all those #'s there. I am a little mechanically ignorant to the technical terms right now. I don't know too many technical numbers. lol
baddis
6
Avon,il
2014
www.mooktank.com
baddis
6
Avon,il
2014
be prepared to spend some money on suspension . as the 4bt weighs in at around 750#. and you need to remove part of the engine xmember. and depending on where you get the engine cou could easely spend upwards of $1900 plus shipping.
Ozwynn
200
Berrien Springs, MI
RE Interceptor
thats the truck that came to mind. thanx
what ever transmission you use, I would use a gear splitter to make better use of the power curve. you will need an over drive transmission unless you like cruising at 50 mph.
