Cv style shaft on rear bw1354
cp2295
7
Washougal, wa
4.0L swap, 8.8 explorer axle, IFS front end
If you ain't first you're last
Hey everyone I’ve been flirting with the idea of doin a doubler on my bronco 2, but got to thinking I’m going to need a double cardan shaft like the front has on the rear. With a single case I already almost need one so definitely would with a doubler. How is everyone mating there double cardan to the back of the 1354?
I couldn’t find any 1310 type yokes that would fit in the rear, maybe the front yoke also fits the rear?
Thanks in advance
-chris
I tried this a few years back, not with a double, but because my CV shaft is damaged and I don't want to repair it, and it almost worked. I got flanged yoke off a spare rear drive shaft for an 80s and it fit. My attempt failed because the shaft was too long.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Couple ways you can do it:
1.
Swap your t-case output flange for a double-cardan CV yoke (same yoke as the front output on a 1354), then you can bolt a CV driveshaft up to the rear.
2. (how I did mine, but probably would do #1 if I was doing it over)
Swap the socket-yoke on the driveshaft for a socket flange (Spicer pt# 211229X), which will allow you to bolt the double-cardan CV to your existing t-case flange.
Forgot something! Junkie reminded me.
I put a front output flange on the rear of the transfer case so the double joint would bolt right up. Then I put a rear flange from an 80s Ranger on the single joint end to boot to the axle.
cstarbard
4
Oakham, MA
2.3
It do like it be
I apologize if I misunderstood anything/this is a dumb response
My 96 2.3 4x4 has a factory double cardan driveshaft in the rear, is there any reason you couldn't get the shaft from a truck like mine and drop it right in? Or lengthen/shorten if needed?
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Would need to be shortened.
There's not very many short-bed std-cab 4x4s out there (the only Rangers to have a CV rear shaft)... You'll have a far easier time finding a front driveshaft and shortening that to fit (don't forget the front t-case output yoke too).
