D30 clicking..?
5speedin2.3
May 2012 OTOTM Winner
Livonia, Mi
2.5L
I've checked everything. The axle joint isn't very old and the bearing rolls smooth.
It's been making this noise, but over the past few weeks it keeps getting louder.
The noise is only when I'm going forward. I've been reading about the brake pads chattering, but I'm not sure if that could be the issue.
Hopefully it isn't anything serious.
http://s88.photobucket.com/albums/k193/daniel_k2006/?action=view&current=9b7a34f1.mp4
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
Sounds like your bearing. Either push and pull the top of the tire to see how much play there is and if any then it may be going out on you. IF you do it with the front off the ground, it will make it much easier to notice.
5speedin2.3
Livonia, Mi
2.5L
Everything seems tight and the bearing rolls smooth.
dangerranger83
54
Lafayette, IN
Hopefully its not something inside of the diff since its right there too.
Just sounds like something is trying to bind up on you.
5speedin2.3
Livonia, Mi
2.5L
I'm pulling the cover tomorrow at the shop. Hopefully it's just the brakes.
If not, I guess we will find out on Saturday.
dangerranger83
54
Lafayette, IN
Find the problem?
5speedin2.3
Livonia, Mi
2.5L
I'm pretty sure it's the brakes.
