jkent
- Mar 12, 2013
- 0
- Wisconsin
- Ford
- Engine Size
- 4.0 OHV
Hello all,
Right now I'm going through most of the D35 in my 93 Ranger and i had a few questions. I bought all three new U-joints and have the outer u joints installed and would like to do the middle u joint, but im not positive how to get the shaft out off the differential. I assume there is a clip inside of the pumpkin..If that is true, what is the easiest way of getting this off? I've read about some C clip eliminator writeups, and i do have the echo spring to put between the passenger shafts, does this spring eliminate the need for the inner c clip? One more question, should there be clips/washers on the outer axle shafts the hold the shafts out(into the lockouts)? My D35 is in pieces right now so i figure this is the time to do the middle u joint and any mods to save me time in the future. I've bought upper and lower moog greaseable balljoints, moog super strength greaseable ujoints, spindle bearings, spindle seals, axle seals, wheel seals, and spindle nuts for the d35, is there anything else im overlooking? Thanks!
