- Feb 28, 2001
- 4,458
- Dayton Oregon
- Ford
- Engine Type
- 2.3 (4 Cylinder)
- Engine Size
- 2.3 Turbo
- 2WD / 4WD
- 4WD
- Total Lift
- 6
- Tire Size
- 35"
I did spindle bearings on my '90 not too long ago with whatever I found, probably long screwdriver and socket like mentioned above...
Those bolts are usually pretty tight, usually takes some work with a 24" breaker bar or if I get desperate hitting the open end of a wrench with a 4lb hammer instead of double wrenching (hammer works better, sometimes a combination of all of the above). I honestly don't remember what I did when I changed the passenger side beam a couple years ago... I'd already had the radius arms off of the replacement beam though so nothing was "freshly obtained)
To pull the pinch bolt for the pumpkin you might be able to beat the radius arm over out of the way, it's been a while since I've tried that too though, I think the last time was in around '11 when I had a '91 Explorer I switched from 3.55 gears to 3.73...
