p38fln
- Jul 26, 2009
- 0
- Superior, WI
- Ford
- Engine Size
- 3.5 L GTDI
my dad just got a 1994 ranger XLT for my brother -
2.3 liter, 108000 miles, no AC, no cruise, and 5 speed transmission, but it does have a sliding rear window
I mean JUST bought as in we haven't even tried to drive it home yet. Anyway, after he test drove it he noticed it ran slightly rough and the brake and ABS lights were on.
My theory - it's got 17 year old spark plugs that were supposed to be replaced 8,000 miles ago. Its probably time to change them, which will probably cure the rough idle. Should anything else be replaced besides the plugs and wires?
The ABS and brake lights are probably on because its low on brake fluid (He did check, it was 1 inch below the "MAX" line). Could this be because it has very worn brakes? (Not sure of the brake condition). I told him just put more fluid in and see what happens, did find on another site that the ABS light on the 1994 Ranger will come on if it gets low on fluid.
Also curious on the clutch adjsutment - I found the manual for the newer 1996 Ranger that says adjust the clutch by lifting on the pedal. Is this the same for the 1994 Ranger? Is it possible to overadjust the clutch?
Also, it's most likely on the original timing belt - I heard its supposed to be replaced at 120K. Should we wait until 120K or is it likely to break before then?
This is a vehicle that has sat a LOT over its long life - under 7,000 miles a year, and sat for months at a time according to the previous owner.
Thanks!
Thanks!
