Dana 35 axle seals
welderman85
Hello I finally got the third member removed now I need to replace the axle seals. How do I go about it . Is there a write up somewhere. thank you
welderman85
Ok I got the driver side out but I'm stumped on the passenger side. Do I need to remove the carrier and drive it in? Thank you
Denisefwd93
74
South East PA
Check the techpages here on the site but I believe you have to pull the c-clip to remove the right side axle
welderman85
Thank you bro removed the clip and shaft . I just not sure if I have to pull the carrier to get that side seal out
Denisefwd93
74
South East PA
Sis, but it's ok, :). No I don't think you have to pull the carrier to get the c-clip out, I don't know I've never actually worked on one I just read a lot
Thank you bro remove the clip and shaft . I just not sure if I have to pull the carrier to get that side seal out
ericbphoto
Overlander in development
TRS 25th Anniversary
16,833
Wellford, SC
3.0L
6"
Denisefwd93
74
South East PA
He was asking about the seals. Sounds like he got the c-clip. Might be able to get the seals from the outside with a puller. I'm not sure.
Sent from my SM-G960U using Tapatalk
I'm pretty sure I read that the seals are pushed from inside. (this is why we did not do them when we did the front end of my truck)
ericbphoto
16,833
Wellford, SC
3.0L
6"
That is by far the easiest way. But may not be the only way.
No members online now.
