reginald fairfield
- Oct 2, 2007
- 0
- New Mexico
- Ford
- Engine Size
- 3.0 liter FF
Hey guys,
I have a 1999 Ranger with the Dana 35 IFS up front. Vacuum Hubs too, but permanently locked(which incidentally I do not reccomend. pinion seal had to be replaced 15,000 miles later). Here is the big question.
Which part of a Dana 35 IFS would be most likely to slip under mid-high rpm or when turning, or when otherwise under load (like climbing a hill...) Something in my front axle seems to clunk and then slip, then grab again. This all happens withing a second, but it keeps doing it every few seconds. It never gets worse either, that is what has astounded me. This slipping has already fried my transfercase once, I had it rebuilt. I am confident that it is not the transfer-case now, though that is what I originally suspected. Could this be a partially stripped hub? A missing tooth on my ring gear? Or maybe the splines on the CV (or whatever) shaft?
If you have had any experience with this, or otherwise have any suggestions, let me know. Thanks in advance fellows.
P.S. This slipping started occuring after a very heavy load was put on the axle at high rpm in four low. Stupid I know, but what is done is done. I just want to be able to use 4-low again.
