dangerranger1983 build
shortzt
Okay thanks, ill have to order some more parts then
shortzt
if you were to do it over would you still use the vert mounts or do 4.0 mounts and plates? i have both i bought some axles and the kid threw in the vert mounts for free.
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
If I had a small body lift then yes to the plates. The plate mounts allow for the engine to sit up higher and my current trans tunnel to floor board clearance is very tight, didn't get my transfercase up as high as I wanted because of not having a BL so that's why I'm having to clearance the trans xmember that others have had no problems clearing.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Congrats on winning the give away bud!
dangerranger83
54
Lafayette, IN
Thanks, didn't know that you knew yet (am I friends with you on FB)
Anyways as said, going to be using the money to put new rotors and pads on the front axle along with replacing the driverside unit bearing if it is going out or not, have a new timken spare already. The age is unknown but it came with the axle when I got it 4 years ago and it's a timken bearing. I don't know the age of the ball joints so I will check them at the same time. I really need to rebuild the axle but getting it 4wd is my main goal.
Also if anybody hasn't heard, if things go as planned the beginning of next year, with the tax money I'm going to be looking for a Ford Escape xlt and sell/trade the tbird for a 2wd standard or extended cab ranger with a 2.3 duratec with a manual trans and get into the mini truck scene. My buddy has one and I love driving it plus it does great on fuel and that's what I want. Also it's cheaper to mod a ranger vs a tbird.
Robert_1967
13
White Pine, TN
302/2.9
Yep, I notice when I traded for thee t-bird that i thought I was going to use a donor, the wheel bolt pattern is not the same as the Ranger, it's a bit smaller, like a 5x4.25 or something.
Robert
posted using a blue blanket and windshield wipers.
dangerranger83
54
Lafayette, IN
That's another annoying thing about them, the odd bolt pattern. To get the mustang and ranger bolt pattern you need to do a mustang hub conversion and that can cost big money to do. The aftermarket is small and expensive for these cars.
Robert_1967
13
White Pine, TN
302/2.9
yep, but can you imagine that engine and rear end setup in a small ranger that is lowered???
Robert
posted using a laptop and keyboard
dangerranger83
54
Lafayette, IN
Yup. The tbird 4.6 is a 2 valve and it only has 205hp from the factory. Problem with the 4.6 is they are stupod crazy wide and a 5.0 is a better choice in my eyes.
The rear ends are IRS and I wouldn't want that.
dangerranger83
54
Lafayette, IN
Shortened and painted. You can see where it had to be heated up to get it to be straight again.
dangerranger83
54
Lafayette, IN
Coil is telling me that it is going out, hard to start when warmed up, hard to start when cold but also if the truck has sat for two weeks, it still cranks over strong but wont give ignition unless I chased the battery over night then it will start the next morning.
Going to get a 50k volt replacement coil soon.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Dang that sucks.
dangerranger83
54
Lafayette, IN
Need an excuse to upgrade the ignition anyways.
Plans are next year to buy the FAST fuel bolt on efi for her...yes that is two grand but I want better mileage and performance plus if I do get another engine and mod it, no need to try and retune a carb or get a custom efi tune with a factor setup.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Why not use stock explorer efi stuff?
dangerranger83
54
Lafayette, IN
Because I don't want all the wiring BS, change intake, etc...plus I would still need a custom tune. My goal is to build a 5.0 with at least 325 at the crank
