dangerranger1983 build
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
I have noted the temp gauge is up there quite a bit like it is telling of its last spot before it was turned off so I'm going to have to check as to why, if it is, getting that hot.
dangerranger83
54
Lafayette, IN
Because I can.
Also took her out for a drive and did 55mph with no issue, vibrations, etc...since it being 4wd again. Also at 55mph my engine is running at 2500rpm...no wonder I only do 8mpg. Definitely need to do different gears in the axles but not until I do the bolt on efi which I've been researching and the one from fast fuel is the best one for the money.
Robert_1967
13
White Pine, TN
302/2.9
Why does it look like the top of your tires are tilted in???
or is that just the way the picture came out??
Robert
posted using a CCA 1500 and blue flame
dangerranger83
54
Lafayette, IN
Picture does that but also I think the driverside unit bearing is going out, I haven't put a new one on it since I got the axle and did the swap almost 4 years ago. Also going to be doing ball joints on it too.
I really need to get the front brakes done before winter.
dangerranger83
54
Lafayette, IN
Going to be going to place this weekend (charity event on private property) to take the truck on a shake down, then may hit the mud bog that is there. Going th be a bunch of other trucks there too.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Nice! Finally getting to try her out huh?
dangerranger83
54
Lafayette, IN
My buddy says he would pay for the gas. I figure see what it can do without throwing a rod through the block or breaking something. There will be plenty of videos and pictures.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Sweet!!! Lookin forward to seeing them!
dangerranger83
54
Lafayette, IN
Had a blast but didn't get as many videos as I wanted. Truck did perfect and had no issues with her.
1983 5.0 Ford Ranger mudding 2: http://youtu.be/YpbxUDq_WS8
Got there and parked next to this. A Bronco with a 400 that had a B2 body swap.
The engine will get cleaned back to the way it was.
Almost done cleaning the under body.
Ford78
December 2012 OTOTM
Iowa
351w
Looking real good! Now the real fun starts, washing her all up!!
dangerranger83
54
Lafayette, IN
I've done must the under body, just need to do the rear suspension, the body and the.engine. Hunting season for deer is coming and so is winter so this was the only play I am going to be doing this year.
dangerranger83
54
Lafayette, IN
Heading to a local off-road park the 25th with Ben Parker, it will be out first time going there. I'm getting my truck prepped for it so far I have the flag and it mount on the truck along with just finishing up welding a skid plate to the bumper to protect the lower radiator from getting as easily damaged.
Have to get the oil changed, try and find a cheap spare in my size and a rim, get my cb mounted and wired up and a couple other things and I should be set.
dangerranger83
54
Lafayette, IN
So for $150 and already pulled, got me an explorer 8.8 l/s with 3.73s
Going to also upgrade to the 3 inch flange and get rid of the 1310-1330 ujoint when I go to install it.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Ooo nice! I've been thinking about doin this to my truck too. Don't some come with 4.10's?
dangerranger83
54
Lafayette, IN
Yup sure do. But because I have 3.73s already, decided to stay with them. Going to either rebuild the clutch pack or shim it to last another year.
