Day time light relay??
trommy
Nova Scotia
2.3
can't find it in the forums or tech library.I saw pics of it here last year but need info on this relay and pic would be nice too.It's a Canadian problem,where do I find the answer??I've a 92 ranger originally from California,nearly as good shape as my buddy's new one.Thanks guys.:icon_thumby:
trommy
Nova Scotia
2.3
These are pt #'s: F6SZ13B218AA kit to add DRL
F8AZ13B218AA kit to add DRL and auto headlamps
__________________
Northern
7
Bryan, TX
2.3
__________________
Trommy,
All you really need are two 30A 5 pin relays
and two 15A fuses, some female spade connectors and a little wire to connect things.
Here is how this mod works..
When your ignition and headlight switch are off, you have no lights, like normal.
When you turn your ignition on, it activated relay 1 ( Normally open ) sending 12V to relay 2 ( normally closed ) turning on your lights.
When you turn on your headlights you activate relay 2 breaking the circuit, how ever you lights will still be on due to the headlight switch being active.
total cost of this mod is around 15 bux with all parts.
