holyford86
Some guy with a problem
- Aug 6, 2007
- 636
- Age
- 37
- Plattsburgh, NY
- many
- Ford
- Engine Size
- 4.0
- 2WD / 4WD
- 4WD
- Total Lift
- 7
- Tire Size
- 33x12.50R15
Engine oil has an oil to coolant sandwich cooler installed. Oiling system is unmodified but has excellent oil pressure and makes no noise. A pusher fan is going to happen, will be on a thermostat plus have an override for when I need it. I like the hood idea and the fact it's easily reversible. Have been running quality synthetic fluids for years now. Cooling system is never an issue, have a huge all aluminum radiator and flush the system every couple years, coolant always stays below 210 degrees. Timing and valvetrain are not adjustable at this time, but timing will be soon enough.@holyford86 ,
• Engine oil remote filter and cooler
• take a look at valve train components for improvements in oil circulation
• electric fan(s), pusher and puller if necessary
• raise the rear of the hood ¼", let's heated air naturally escape as it rises
• all synthetic fluids
• lower temp thermostat, even 5° F makes a HuGE difference.
• cooling system in tip top condition
• optimized timing for setup
• proper valve train adjustment
Two words: cop magnet. New York is fun...My truck is a driver...I don't have ac....so I drop the doors in summer generally....
Lil bob......runs hoodless.
View attachment 90112View attachment 90113
Hoods are overrated....
It just barely fits, ish.Especially when your hood won't fit over your engine
I had always been under the impression that a high pressure area forms at the base of the windshield so this makes sense. The cowl I have was done out of necessity because a part of the engine just barely hits the hood, I've always disliked the look and may replace the hood, along with adding a lump to clear what I need to.As a rule, for better body aerodynamics, modern vehicles are designed to channel airflow through the engine compartment (after the radiator) down under the body/frame instead of up over the windshield when in motion. This is why you now seldom see factory performance cars with big engine vents in the original hood. Just wanted to mention that, as you might have to go to extremes to get a lot of heat to vent up instead of down.
Notice that your coolant temperature is just fine despite your performance mods. That's a sign the airflow is still venting as the factory designed, under the cab and frame. That's why the cab interior stays warm.
Modifying the fender liners will do more than worrying about changing the hood.
I've always thought it to be important to upgrade supporting systems when doing mods, I'm running 6 psi and have headers, even though the heads dont flow well, haha. Even before I did this I knew I was going to, so I added an oil cooler and larger radiator in anticipation. Coolant temp has not risen appreciably with the boost, so I figure I did a decent job.
Heat rising through the floor definetly happens but running no carpet or insulation of any kind doesn't help. That's what I've got windows for.
