deciphering what axles
treel98
NorthWest Indiana
2.9 for now
How do i tell what axles i have on my 1990 bronco ii 2.9 auto. And what are the best axles for a SAS
BabyBronco89
GR Michigan
95' 4.0 OHV
78-79 Dana 44 HP and 9" full size are the best in my opinion for SAS,
A Dana 28 is visually smaller a Dana 35 is bigger you can count the bolts on the diff to verify which one you have, look inside the drivers door for axle codes this will tell you what ratio and if you have trac lock l/s
The rear is a 7.5, no questions asked.
On the front, count the bolts. 10 bolts is a 35, 12 bolts is a 28. I know that sounds bass-ackwards, but it isn't.
It's probably a 35 in 1990.
treel98
NorthWest Indiana
2.9 for now
what is better to have the dana 28 or the dana 35 and how hard is a SAS on a scale of 1 - 10
1 easiest 10 hardest
alwaysFlOoReD
5,102
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
What are your plans for your truck? (what size tires, what kind of wheeling?)
The D35 is a quite capable right out of the box and with just a few mods such as the Jeep hub swap and maybe 5-760X u-joints can spin 35" tires without worry. A D44 swap would get you larger brakes, but strengthwise it is more similar than different (which there are ways to swap said brakes onto the D35 as well).
If you have the D28, a D35 just bolts in it's place (if you don't have a lift, you'll likely need to shorten the driveshaft an inch).
If you still want to SAS, then I strongly suggest you get to reading about it. And then read some more.
There's a lot of different axles you can choose from (some better than others). Without knowing anything about your planned use or your skill level, none of us can even begin to tell you what axle is best or how easy it will be.
BabyBronco89
GR Michigan
95' 4.0 OHV
i like to judge skill level based off your arsenal of tools,
if you don't own a big red box, with duplicates of most things, and you've never broken a half inch drive ratchet, and you don't own a grinder, your probably not skilled enough to get the job done, like wise, if you have all these things and know how to use them you'll probably be fine, if not you most likely have a buddy that might know how to use them better then you, and help is always appreciated.
My SAS D44 and 9" took about a yr and a half from conception to pavement.
now all that time wasn't spent busting knuckles and turning wrenches.
I collected parts and prepped parts and painted them, ordered more parts, read studied, read some more, asked more questions, and did more research.
The actual job took about a month working by myself on my days off, and after work.
it definitely could of been quicker, but i wasn't in a hurry, and i was still putting pieces of the puzzle together, including waiting over 2 weeks for the last piece of the puzzle (my shocks) so i could drive it. you effetely want to have another vehicle for the time that your truck is down
overall id say a skill level of 5 or higher is okay but 7 or above is preferred.
If you look in extreme suspensions you can find my build thread, look it over, read others, you'll learn lots of useful stuff
treel98
NorthWest Indiana
2.9 for now
Well in terms of what i want to do with my truck i want 35's better brakes and more strength. The kind of wheeling i do is a little bit of everything i do minor rock crawling through some pretty rough creek beds, I like to throw it in mud holes, and trails. But the thing is that i will need to to be able to be daily drivin. Not expressway driven but definitely needs to be able to make the 15 mile run to town easily i don't want to have to fight it running all over the road.
BabyBronco89
GR Michigan
95' 4.0 OHV
I daily drive my b2 with the SAS and 5.5" lift I have hit 80 on the highway no problem it stops good and handles great, I drive 30 miles to and from work every day 15 miles high way and 15miles on the rural back roads at 55mph I love my full size axles
treel98
NorthWest Indiana
2.9 for now
what axles are you using?
